{"product_id":"replica-cast-iron-oil-pump-assembly-v-twin-12-9931-oem-26201-48d","title":"Replica Cast Iron Oil Pump Assembly - V-Twin 12-9931 - OEM 26201-48D","description":"\u003cp\u003e\u003cstrong\u003eOEM #:\u003c\/strong\u003e 26201-48D\u003c\/p\u003e\n\u003cp\u003eReplica cast iron oil pump assembly includes the correct oil pressure switch.\u003c\/p\u003e\n\u003cp\u003eAssembly is exact for the years listed! Outer cover is die cast as original for accurate restoration details. **NOTE: The oil pump flow rate is the same as stock flow. *NOTE: Welch plug is used to seal oil diffuser plate installation. See details in related photos.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eSuggested to use with Engine case.619 Welch Plug.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1949-1954\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67807754322078,"sku":"12-9931","price":569.99,"currency_code":"USD","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/12-9931-replica-cast-iron-oil-pump-assembly-oem-26201-48d-1.jpg?v=1792857870","url":"https:\/\/chopcult.com\/products\/replica-cast-iron-oil-pump-assembly-v-twin-12-9931-oem-26201-48d","provider":"ChopCult","version":"1.0","type":"link"}
