{"product_id":"replica-black-oil-tank-v-twin-40-0472","title":"Replica Black Oil Tank - V-Twin 40-0472","description":"\u003cp\u003eReplica 1937 oil tank includes original style and accoutrements in black finish. Tank has embossed smooth edge top welded panel. The oil cap included features a shot peen finish.\u003c\/p\u003e\n\u003cp\u003eBottom feed hole is 3\/4 inch - 20 TPI and requires a fitting to resize the hole to 1\/2 inch - 20 TPI for the banjo bolt. The left vent hole is 3\/8 inch - 24 TPI. The right return hole is 1\/2 inch - 20 TPI. We suggest to use taps to clean the threads before installing the oil lines. *NOTE: Must order oil line banjo fitting and oil feed valve separately. *NOTE: Features 1\/8 NPT internal threads for vent and return lines. *NOTE: The battery compartment dimensions are 5 inch wide x 4-1\/2 inch long x 7 inch tall.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eHeight Front: 7 inches\u003c\/li\u003e\n\u003cli\u003eHeight Rear: 6-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eDepth: 8-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eDepth of Battery: 5 inches\u003c\/li\u003e\n\u003cli\u003eWidth: 10 inches\u003c\/li\u003e\n\u003cli\u003eBattery Width: 4-7\/8 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eRequires the use of Oil Banjo Line Fitting and Banjo Fitting Bolt for Feed and Return Oil Lines.\u003c\/li\u003e\n\u003cli\u003eRequires the use of Feed Oil Line washer for Cadmium Feed and Cadmium Return Oil Lines.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with #9601-10 Inner Primary Cover and Chain Mount Kit.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Oil Feed Valve Assembly Zinc Plated.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1937\u003c\/td\u003e\n\u003ctd\u003eEL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1937\u003c\/td\u003e\n\u003ctd\u003eUL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/40\/40-0472.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67553019494558,"sku":"40-0472","price":229.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/40-0472-replica-black-oil-tank-1.jpg?v=1792133643","url":"https:\/\/chopcult.com\/products\/replica-black-oil-tank-v-twin-40-0472","provider":"ChopCult","version":"1.0","type":"link"}
