{"product_id":"replica-74-panhead-cylinder-piston-kit-v-twin-11-0885","title":"Replica 74 Panhead Cylinder Piston Kit - V-Twin 11-0885","description":"\u003cp\u003eThis 74 inch Panhead cylinder and piston kit is bored and honed to 87.325mm with a stock compression of 8.5:1. Cylinders have original casting marks as on stock cylinders for this year group.\u003c\/p\u003e\n\u003cp\u003eBoth cylinders are equipped with oil passages drilled through the wall to allow oil to return through the bore to the crank case. Pistons are pre-fit ready to run. Break in slowly first 500 miles. *NOTE: All cast iron cylinders have same piston to wall clearance.0025 -.003. Bore size is 3.4380 inch-3.4385 inch inner diameter.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eCylinders have M-1-0 date code.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1948-1952\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/Piston%20Fitment.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67549346168990,"sku":"11-0885","price":589.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/11-0885a.jpg?v=1791649063","url":"https:\/\/chopcult.com\/products\/replica-74-panhead-cylinder-piston-kit-v-twin-11-0885","provider":"ChopCult","version":"1.0","type":"link"}
