{"product_id":"replica-74-overhead-valve-piston-set-standard-size-v-twin-11-0216-oem-22101-74a","title":"Replica 74 Overhead Valve Piston Set Standard Size - V-Twin 11-0216 - OEM 22101-74A","description":"\u003cp\u003e\u003cstrong\u003eOEM #:\u003c\/strong\u003e 22101-74A\u003c\/p\u003e\n\u003cp\u003eReplica style 3-7\/16 inch bore piston set has 8.5:1 compression ratio and is standard size. Piston set includes Hasting rings 2 wrist pins and 4 circlips. Pistons have a steel expansion control strut cast.\u003c\/p\u003e\n\u003cp\u003e**Note: Run engine at moderate speeds for at least 500 miles avoiding excessive running in lower gears in order to properly break-in new pistons and rings. Bore size is 3.4380 inch-3.4385 inch inner diameter.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1941-1977\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1971-1977\u003c\/td\u003e\n\u003ctd\u003eFX\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/Piston%20Fitment.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67549318119582,"sku":"11-0216","price":129.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/11-0216.jpg?v=1791648472","url":"https:\/\/chopcult.com\/products\/replica-74-overhead-valve-piston-set-standard-size-v-twin-11-0216-oem-22101-74a","provider":"ChopCult","version":"1.0","type":"link"}
