{"product_id":"replica-1936-knucklehead-black-oil-tank-v-twin-40-0636","title":"Replica 1936 Knucklehead Black Oil Tank - V-Twin 40-0636","description":"\u003cp\u003eReplica 1936 Knucklehead wrap around oil tank is the original type with female fittings for banjo bolts. Features a non embossed smooth top lower panels and comes with a drain plug.\u003c\/p\u003e\n\u003cp\u003eBlack tank has a zinc plated cap and is equipped with a screw in dipstick that includes a copper sealing washer. Tank does not have battery rod tabs. *NOTE: Must order banjo bolts and fittings for oil lines separately. Lower right hand feed outlet must be tapped larger to fit a banjo bolt. *NOTE: Can be used in later applications by changing the battery rods to earth style battery rods. *NOTE: Features 1\/8 NPT internal threads for vent and return lines. *NOTE: The battery compartment dimensions are 5 inch wide x 4-1\/2 inch long x 7 inch tall. The left vent hole is 3\/8 inch-24 TPI and the right return hole is 1\/2 inch-20 TPI. Clear threads with a tap before final assembly. (Recommended) Cap is included. Requires the purchase of rubber or steel fittings for oil lines.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use with Oil Feed Valve Assembly Zinc Plated.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with #3003-3 Oil Line Banjo Bolt and Washer Kit.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with #3069-3 Oil Tank Vent Pipe Nipple Bolt and Washer Kit.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Replica Oil Tank Plate.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1936-1940\u003c\/td\u003e\n\u003ctd\u003eEL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1941-1957\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1938-1947\u003c\/td\u003e\n\u003ctd\u003eUL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67553024376990,"sku":"40-0636","price":369.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/40-0636-replica-1936-knucklehead-black-oil-tank-1.jpg?v=1792133764","url":"https:\/\/chopcult.com\/products\/replica-1936-knucklehead-black-oil-tank-v-twin-40-0636","provider":"ChopCult","version":"1.0","type":"link"}
