{"product_id":"rear-pulley-brake-disc-spacer-steel-1-2-thickness-york-144369-big-twin-0","title":"Harley Rear Pulley Brake Disc Spacer Steel 1\/2 Thickness - York 144369 - Big Twin 0+","description":"\u003cp\u003eSteel spacer is 1\/2 inch thick with 7\/16 inch bolt holes. This spacer is ideal to get belt pulleys and chain sprockes in line. Spacer can be machined down to the next size under without having to worry about the spigot alignment when you machine the face of the spacer down to the desired thickenss. This also can be used as a disc spacer. *NOTE: Inner Diameter is 2-1\/4 inch to fit 2000-UP rear hubs on FX FL and XL models. Universal fit for most Harley applications.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eYork #:\u003c\/strong\u003e 144369\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\n\u003cul\u003e\u003cli\u003eInner Diameter: 2.25 inches\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\n\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"York","offers":[{"title":"Default Title","offer_id":67550898159774,"sku":"20-0148","price":29.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/20-0148-rear-pulley-brake-disc-spacer-steel-1-2-thickness-york-144369-big-twin-0-1.jpg?v=1792110349","url":"https:\/\/chopcult.com\/products\/rear-pulley-brake-disc-spacer-steel-1-2-thickness-york-144369-big-twin-0","provider":"ChopCult","version":"1.0","type":"link"}
