{"product_id":"rear-axle-spacer-3-4-inner-diameter-paughco-33d2","title":"Harley Rear Axle Spacer 3\/4 Inner Diameter - Paughco 33D2","description":"\u003cp\u003eAxle spacer kit for the rear wheel, setting correct hub spacing and including the washers and nut needed for a clean install. Universal fit for most Harley axle applications.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003ePaughco #:\u003c\/strong\u003e 33D2\u003c\/p\u003e\n\u003cp\u003eChrome rear axle spacer have milled flat section on one end to fit rigid frame slots. The collar has an overall length of 1-13\/16 inch x 3\/4 inch inner diameter.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eOverall Length: 1-13\/16 inches\u003c\/li\u003e\n\u003cli\u003eInner Diameter: 3\/4 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use with collar\u003c\/li\u003e\n\u003cli\u003eSuggested to use with rear axle nut \u0026amp; washer kit\u003c\/li\u003e\n\u003cli\u003eSuggested to use with #7704-2 rear chain adjuster set\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Paughco","offers":[{"title":"Default Title","offer_id":67553327251614,"sku":"44-1987","price":84.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/44-1987-rear-axle-spacer-3-4-inner-diameter-paughco-33d2-1.jpg?v=1792136356","url":"https:\/\/chopcult.com\/products\/rear-axle-spacer-3-4-inner-diameter-paughco-33d2","provider":"ChopCult","version":"1.0","type":"link"}
