{"product_id":"raw-spring-fork-front-fender-v-twin-50-0750","title":"Harley Big Twin Raw Spring Fork Front Fender - V-Twin 50-0750","description":"\u003cp\u003eRaw spring fork-style front fender, a direct replacement for a dented, rusted, or missing stock fender. Fits 1936-1946 Harley Flathead and Knucklehead models.\u003c\/p\u003e\n\u003cp\u003eSpring Fork front fender with raw finish OE style rivets a one piece seamless fender body and narrow braces\u003c\/p\u003e\n\u003cp\u003eFender braces fit on the outside of the offset rockers. We suggest pre fitting the fender prior to painting. Before priming or painting fit the fender body braces and mounting points in place. Fender rivets hinge and brackets will have to be tweaked for final fitment. Patience is required for proper installation! The narrow braces are riveted into place and the side panels are pressed instead of being spot welded into place. *NOTE: The measurement between the 2 holes on the top of the fender where the fender mounts to the fork is 4-1\/2 inch. The inner diameter between the braces measures 11-5\/8 inch. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eFender Width: 7-1\/4 inches\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1936-1940\u003c\/td\u003e\n\u003ctd\u003eEL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1941-1946\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1937-1946\u003c\/td\u003e\n\u003ctd\u003eUL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67553997127838,"sku":"50-0750","price":169.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/50-0750-raw-spring-fork-front-fender-1.jpg?v=1792140025","url":"https:\/\/chopcult.com\/products\/raw-spring-fork-front-fender-v-twin-50-0750","provider":"ChopCult","version":"1.0","type":"link"}
