{"product_id":"raw-rear-axle-v-twin-44-0638-big-twin-0","title":"Harley Raw Rear Axle - V-Twin 44-0638 - Big Twin 0+","description":"\u003cp\u003eRaw, unfinished rear axle ready for your choice of finish — a direct OEM-spec replacement for a worn, bent, or rusted stock axle. Universal fit, replaces the stock axle on most Harley applications.\u003c\/p\u003e\n\u003cp\u003eRaw axle with 3\/4 inch threaded ends has a 11-3\/8 inch bearing surface length and can be used to replace a worn out or damaged axle.\u003c\/p\u003e\n\u003cp\u003eThese axles features 1 inch of 3\/4 inch x 16 threads at each end. An acorn pike or nyloc nut can be used. Locators are set to fit axles in order to stock rigid frame axle plates.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eBearing Surface: 11-3\/8 inches\u003c\/li\u003e\n\u003cli\u003eSurface w\/o Thread:\u003c\/li\u003e\n\u003cli\u003eOverall Length: 13-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eOuter Diameter: 3\/4 inches\u003c\/li\u003e\n\u003cli\u003eThreads per Inch: 16\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eSuggested to use nut kit.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67553295925406,"sku":"44-0638","price":49.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/44-0638-raw-rear-axle-big-twin-0-1.jpg?v=1792136072","url":"https:\/\/chopcult.com\/products\/raw-rear-axle-v-twin-44-0638-big-twin-0","provider":"ChopCult","version":"1.0","type":"link"}
