{"product_id":"rattle-bomb-spray-kit-burgundy-rattle-bomb-rbkit-win","title":"Rattle Bomb Spray Kit Burgundy - Rattle Bomb RBKIT-WIN","description":"\u003cp\u003e\u003cstrong\u003eRattle Bomb #:\u003c\/strong\u003e RBKIT-WIN\u003c\/p\u003e\n\u003cp\u003eBurgundy Rattle Bomb spray kit includes 3 colors: cherrie pie base cherrie pie flake wino kandy and a clear coat. Roth flake cans are a super convenient way to lay down serious flake without the hassle of a spray and clean up.\u003c\/p\u003e\n\u003cp\u003eKit is ideal for Peanut and Chopper fender set! For maximum coverage we suggest using the whole kit. Painters can get a big sparkle look with small flake (.004 inch). The coverage of a single can of Base and Flake is about 5 square feet per can. For the kits each can goes on top of the last so we estimate coverage at 5 square feet. Generally for a motorcycle (tank and two fenders) we recommend 3 kits. Note to use a single kit for a tank. These can flake aerosolas have tiny flakes that need to be layered. You need a good primer coat and solid base coat. The base coat should match your flake coat if you want to achieve a saturated uniform color. One can of flake over the same color base coat will have a very low flake saturation. Several cans of flakes are needed for a super saturated effect.Always paint in a ventilated area. Use a test panel before you start. These are professional grade paints recommended to use by a professional. Sold in a set of four.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eAll\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Rattle Bomb","offers":[{"title":"Default Title","offer_id":67553078182046,"sku":"41-0880","price":129.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/41-0880-rattle-bomb-spray-kit-burgundy-rattle-bomb-rbkit-win-1.jpg?v=1792134165","url":"https:\/\/chopcult.com\/products\/rattle-bomb-spray-kit-burgundy-rattle-bomb-rbkit-win","provider":"ChopCult","version":"1.0","type":"link"}
