{"product_id":"prism-2-2-gallon-gas-tank-v-twin-38-0242","title":"Prism 2.2 Gallon Gas Tank - V-Twin 38-0242","description":"\u003cp\u003eGas tank has a left side petcock opening and a fuel capacity of 2.2 gallons. It includes front and rear mount tabs.\u003c\/p\u003e\n\u003cp\u003eThis Wyatt Gatling tank features a mini design which allows for full engine view. Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. Petcock fitting should be masked or plugged during painting for easy installation of petcock. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs. Fromt he top mount center to the bottom mount center measures 14-1\/8 inch.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 22-3\/8 inches\u003c\/li\u003e\n\u003cli\u003eBottom Length: 17 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 0.75 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 8 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 0.5 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 6-7\/8 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height: 1-3\/8 inches\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Height: 5\/8 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Length: 19-1\/8 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Width: 2 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552816824478,"sku":"38-0242","price":269.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0242-prism-2-2-gallon-gas-tank-1.jpg?v=1792132011","url":"https:\/\/chopcult.com\/products\/prism-2-2-gallon-gas-tank-v-twin-38-0242","provider":"ChopCult","version":"1.0","type":"link"}
