{"product_id":"porkster-3-2-gallon-gas-tank-single-cap-v-twin-38-0025-sportster-2004-2006","title":"Porkster 3.2 Gallon Gas Tank Single Cap - V-Twin 38-0025 - Sportster 2004-2006","description":"\u003cp\u003eGas tank has a raw finish with a left side petcock location and a fuel capacity of 3.2 gallons.\u003c\/p\u003e\n\u003cp\u003eTank is dual cap type. This tank is shorter in length than the stock tank. Tank accepts stock components and is for carburetor models. Use with 1975-up petcock and proper hardware for installation process. Check the tank for flaws and fit the tank qwill require sanding and primer before paiting. Do not grind or sand the seams or joints. check the petcock opening making sure the petcock can be easily installed. The petcock fitting should be masked or plugged during painting for easy installation of the petcock. It is suggested to pressure test and use a tank sealer. We suggets using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. *NOTE: This item contains a chemical that is know to cause cancer or birth defects. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 21 inches\u003c\/li\u003e\n\u003cli\u003eBottom Length: 18 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 6 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 15 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 2 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 8 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height: 4-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Height: 19-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Length: 19-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Width: 3.590 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e2004-2006\u003c\/td\u003e\n\u003ctd\u003eXL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/38\/38-0025.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552807583902,"sku":"38-0025","price":169.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0025-porkster-3-2-gallon-gas-tank-single-cap-sportster-2004-2006-1.jpg?v=1792131906","url":"https:\/\/chopcult.com\/products\/porkster-3-2-gallon-gas-tank-single-cap-v-twin-38-0025-sportster-2004-2006","provider":"ChopCult","version":"1.0","type":"link"}
