{"product_id":"porkster-3-2-gallon-gas-tank-kit-dual-cap-v-twin-38-0071-evolution-sportster-1995-2003","title":"Porkster 3.2 Gallon Gas Tank Kit Dual Cap - V-Twin 38-0071 - Evolution Sportster 1995-2003","description":"\u003cp\u003eGas tank is dual cap style with a left side petcock location and a fuel capacity of 3.2 gallons. Kit includes gas tank coil mount relocation kit.\u003c\/p\u003e\n\u003cp\u003eIncludes coil\/ignition switch kit. Tank features a smooth top. Kit utilizes a 22mm nut type petcock order separately. Please test fitment before painting. Tank weld seams may require filler to meet your individual requirements. Do not grind or sand the seams or joints as this may cause leaks. We suggest using Kreem gas tank combo kit to clean condition and seal. This will help stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. Petcock fitting should be masked or plugged during painting for easy installation of petcock. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 19\u003c\/li\u003e\n\u003cli\u003eBottom Length: 18-7\/8 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 7-3\/8 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 14 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 2-5\/16 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 8-5\/8 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height: 4-5\/8'\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Height: 1.5 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Length: 18-1\/8 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eIncludes VT # Gas Tank Coil Mount Relocation Kit.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Gas Tank Mounting Kit.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1995-2003\u003c\/td\u003e\n\u003ctd\u003eXL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/38\/38-0071.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552808763550,"sku":"38-0071","price":289.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0071-porkster-3-2-gallon-gas-tank-kit-dual-cap-evolution-sportster-1995-2003-1.jpg?v=1792131919","url":"https:\/\/chopcult.com\/products\/porkster-3-2-gallon-gas-tank-kit-dual-cap-v-twin-38-0071-evolution-sportster-1995-2003","provider":"ChopCult","version":"1.0","type":"link"}
