{"product_id":"polished-engine-breather-oil-collector-v-twin-40-0568","title":"Harley Polished Engine Breather Oil Collector - V-Twin 40-0568","description":"\u003cp\u003ePolished oil collector is designed to collect the oil mist from the breather hose which eliminates engine oil from collecting in air cleaner. On top is a high flow air filter that acts as a baffle allowing the oil and air to separate more efficiently and can easily be cleaned. On the bottom is a drain plug to allow drainage on a regular basis. A 90° barbed fitting fits breather hoses perfectly and includes chrome mounting billet clamp. *NOTE: Order strp steel clamp if prefered ehich can then be cut to length. *NOTE: So the clamp does not slip when you tighten the fittings it's suggested to use sand paper or a file to rough up the band where the clamp fits. (See diagram) Installation instructions (PDF). Universal fit for most Harley applications.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003eLength: 2-3\/4 inches\u003c\/li\u003e\n\u003cli\u003eWidth: 1-1\/2 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\n\u003cul\u003e\u003cli\u003eSuggested to use with #31-2100 Chrome 1-1\/2inch Exhaust Hanger Clamp Set.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\n\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67553023197342,"sku":"40-0568","price":94.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/40-0568-polished-engine-breather-oil-collector-1.jpg?v=1792133725","url":"https:\/\/chopcult.com\/products\/polished-engine-breather-oil-collector-v-twin-40-0568","provider":"ChopCult","version":"1.0","type":"link"}
