Pangea Speed
Pangea Speed - Phong Brake Pedal
$164.99 USD
$164.99 USD
This brake pedal is designed to work with Harley big twin frames from 36-57 with the cross over shaft and a mechanical rear brake. This will clean up your brake side and get rid of a bunch of linkages. note: running this "LEE" style pedal will make your left side brake linkage push instead of pull, you should run our brake cross over gear set to correct this issue. COMES CHROME PLATED
