{"product_id":"oko-47mm-shorty-carburetor-kit-v-twin-35-1830-ironhead-1966-1977","title":"OKO 47mm Shorty Carburetor Kit - V-Twin 35-1830 - Ironhead 1966-1977","description":"\u003cp\u003ePerformance 47mm shorty carburetor with natural finish. Kit will accept S\u0026amp;S bolt pattern air filter assemblies. It has a relocated accelerator pump nozzle for increased throttle response. Uses flat sealing ring for manifold.\u003c\/p\u003e\n\u003cp\u003eIncludes Shorty Carburetor Air Snoot with door. This is the R-2 version of the OKO type replacement carburetor. OKO shorty carburetor accepts S\u0026amp;S air cleaners Shorty E carburetor components and rebuild parts. All pieces interchangeable. Air cleaner mount bolt configuration is S\u0026amp;S inchE inch type. *NOTE: Requires carburetor support bracket to mount to the air cleaner and stud between the cylinders. Additonal holes in the air cleaner backing plate may be needed for mounting. *NOTE: 1-7\/8 inch = 47mm. Use with dual cable throttle\/assembly cable. *NOTE: The main jet installed is #190. *NOTE: Kit is supplied with brand type intake manifold and band seal set. Kit fits with the inchstepped inch conversion rings if used on a pre 1978 application (o-ring). Snoot is not an air cleaner but for the air intake only. We suggest using Loctite for proper installation.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1966-1977\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1973-1977\u003c\/td\u003e\n\u003ctd\u003eFX\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1966-1977\u003c\/td\u003e\n\u003ctd\u003eXL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67552466337950,"sku":"35-1830","price":369.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/35-1830-oko-47mm-shorty-carburetor-kit-ironhead-1966-1977-1.jpg?v=1792129384","url":"https:\/\/chopcult.com\/products\/oko-47mm-shorty-carburetor-kit-v-twin-35-1830-ironhead-1966-1977","provider":"ChopCult","version":"1.0","type":"link"}
