{"product_id":"oko-47mm-shorty-carburetor-kit-v-twin-35-1780-ironhead-1966-1977","title":"OKO 47mm Shorty Carburetor Kit - V-Twin 35-1780 - Ironhead 1966-1977","description":"\u003cp\u003ePerformance 47mm shorty carburetor with natural finish. Kit will accept S\u0026amp;S bolt pattern air filter assemblies. It has a relocated accelerator pump nozzle for increased throttle response. Uses flat sealing ring for manifold.\u003c\/p\u003e\n\u003cp\u003e*NOTE: Air cleaner not included. This is the R-2 version of the OKO type replacement carburetor. OKO shorty carburetor accepts S\u0026amp;S air cleaners Shorty E carburetor components and rebuild parts. All pieces interchangeable. Air cleaner mount bolt configuration is S\u0026amp;S inchE inch type. *NOTE: Requires carburetor support bracket to mount ot the air cleaner and stud between the cylinders. Additional holes in the air cleaner backing plate may be needed for mounting. Use with dual cable throttle\/assembly cable. *NOTE: The main jet installed is #190. *NOTE: 1-7\/8 inch = 47mm. We suggest using Loctite for proper installation.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eRequired to use with OKO Carburetor Enrichment Assembly if used with custom air cleaners because the enricher will have to be changed.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1966-1977\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1973-1977\u003c\/td\u003e\n\u003ctd\u003eFX\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1966-1977\u003c\/td\u003e\n\u003ctd\u003eXL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67552465780894,"sku":"35-1780","price":269.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/35-1780-oko-47mm-shorty-carburetor-kit-ironhead-1966-1977-1.jpg?v=1792129353","url":"https:\/\/chopcult.com\/products\/oko-47mm-shorty-carburetor-kit-v-twin-35-1780-ironhead-1966-1977","provider":"ChopCult","version":"1.0","type":"link"}
