{"product_id":"oko-42mm-flatside-carburetor-kit-v-twin-35-1880-ironhead-1966-1984","title":"OKO 42mm Flatside Carburetor Kit - V-Twin 35-1880 - Ironhead 1966-1984","description":"\u003cp\u003eOKO 42mm flatside carburetor kit includes vertical flange adapter rubber sleeve air cleaner adapter lower carburetor stud and strap bracket. *Shown installed on a 1966 flatside Shovelhead.\u003c\/p\u003e\n\u003cp\u003e42mm band type manifold included with adapter rings to fit o-ring style manifold heads. Includes 4 main jets and 2 pilot jets. The carburetoer outer flange adapter is a molded rubber sleeve with a CV pattern alloy flange. Requires dual cable push-pull operation. Twist grip and cables available separately.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use with stock cables: 34inch Stainless Steel Throttle and Idle Cable set or 34.92inch Black Throttle and Idle Cable Set.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with 8+ cables: 41-1\/2inch Stainless Steel Throttle and Idle Cable Set or 41-1\/2inch Black Throtle and Idle Cable Set.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Dual Handlebar Throttle Hanlde and Grips.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1966-1984\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1971-1984\u003c\/td\u003e\n\u003ctd\u003eFX\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1966-1984\u003c\/td\u003e\n\u003ctd\u003eXL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67552466665630,"sku":"35-1880","price":309.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/35-1880-oko-42mm-flatside-carburetor-kit-ironhead-1966-1984-1.jpg?v=1792129402","url":"https:\/\/chopcult.com\/products\/oko-42mm-flatside-carburetor-kit-v-twin-35-1880-ironhead-1966-1984","provider":"ChopCult","version":"1.0","type":"link"}
