{"product_id":"left-side-ul-engine-case-v-twin-10-0879-oem-24536-37","title":"Left Side UL Engine Case - V-Twin 10-0879 - OEM 24536-37","description":"\u003cp\u003e\u003cstrong\u003eOEM #:\u003c\/strong\u003e 24536-37, 410-37, 406-37\u003c\/p\u003e\n\u003cp\u003eSide valve replacement left side engine case features a blank number boss. This case has the same oil passage for the outside sprocket shaft bearing as the original case.\u003c\/p\u003e\n\u003cp\u003eNOTE: Left side case must be fitted to existing OE right side case. Cylinder base surfaces and motor mount surfaces must be milled to match before assembly. *NOTE: Requires hole to be drilled in the left case. Cast in the bushing after the case race has been pressed in. Install the race and then drill the hole. *NOTE: Left side cases accept standard case race.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eSuggested to use with Sprocket Left Side Case Race Standard.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1937-1948\u003c\/td\u003e\n\u003ctd\u003eUL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67549221617822,"sku":"10-0879","price":619.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/10-0879a.jpg?v=1791646181","url":"https:\/\/chopcult.com\/products\/left-side-ul-engine-case-v-twin-10-0879-oem-24536-37","provider":"ChopCult","version":"1.0","type":"link"}
