{"product_id":"laredo-3-1-gallon-dished-gas-tank-raw-v-twin-38-0682","title":"Laredo 3.1 Gallon Dished Gas Tank Raw - V-Twin 38-0682","description":"\u003cp\u003eLaredo style gas tank with dished sides has a 3\/8 inch NPT right hand petcock opening and a fuel capacity of 3.1 gallons. Features a right side bung for 1983-2017 screw-in type gas caps.\u003c\/p\u003e\n\u003cp\u003eThe left and right hand rear connectors are 1\/4 inch NPT. Features universal mounting brackets for easier mounting. Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stp leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. Petcock fitting should be maked or plugged during painting for easy installation of petcock. *NOTE: UPS may consider this part as packaged inchoversize inch as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eLength: 17 inches\u003c\/li\u003e\n\u003cli\u003eWidth: 11-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eLow Tunner Width: 2 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67552850772126,"sku":"38-0682","price":249.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0682-laredo-3-1-gallon-dished-gas-tank-raw-1.jpg?v=1792132290","url":"https:\/\/chopcult.com\/products\/laredo-3-1-gallon-dished-gas-tank-raw-v-twin-38-0682","provider":"ChopCult","version":"1.0","type":"link"}
