{"product_id":"koffin-style-3-4-gallon-gas-tank-wyatt-gatling-03-0175","title":"Koffin Style 3.4 Gallon Gas Tank - Wyatt Gatling 03-0175","description":"\u003cp\u003e\u003cstrong\u003eWyatt Gatling #:\u003c\/strong\u003e 03-0175\u003c\/p\u003e\n\u003cp\u003eGas tank accepts a left side petcock with a 3\/8 inch National Pipe Thread. Fuel capacity is 3.4 gallons. Tank features ISO mount strap system.\u003c\/p\u003e\n\u003cp\u003e*NOTE:Includes 2 black brackets and bolts. Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. The petcock fitting should be masked or plugged during painting for easy installation of the petcock. Tank features a second petcock hole that can utilize 1\/4 NPT similar to a mini petcock 90°. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 25.5 inches\u003c\/li\u003e\n\u003cli\u003eBottom Length: 20 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 3 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 12 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 2.5 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 6 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height: 4 inches\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Height: 1 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Length: 24 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Width: 2-1\/4 inches\u003c\/li\u003e\n\u003cli\u003eMount Hole: 4.45 inches CTC\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use with Mini Petcock 90° without Bearing.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Smooth Style Gas Cap Vented\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552813645982,"sku":"38-0199","price":359.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0199-koffin-style-3-4-gallon-gas-tank-wyatt-gatling-03-0175-1.jpg?v=1792131989","url":"https:\/\/chopcult.com\/products\/koffin-style-3-4-gallon-gas-tank-wyatt-gatling-03-0175","provider":"ChopCult","version":"1.0","type":"link"}
