{"product_id":"koffin-style-2-2-gallon-gas-tank-v-twin-38-0172","title":"Koffin Style 2.2 Gallon Gas Tank - V-Twin 38-0172","description":"\u003cp\u003eRaw gas tank accepts a left or right side 1\/4 inch National Pipe Thread petcock and has a fuel capacity of 2.2 gallons. It has a single front tab and a rear U-bracket.\u003c\/p\u003e\n\u003cp\u003eUse proper hardware for installation process. Please test fitment before painting. Tank weld seams may require filler to meet your individual requirements. Do not grind or sand the seams as this may cause leaks. We suggest using Kreem gas tank combo kit to clean condition and seal. This will help to stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. Petcock fitting should be masked or plugged during painting for easy installation of petcock. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 18 inches\u003c\/li\u003e\n\u003cli\u003eBottom Length: 17 inches\u003c\/li\u003e\n\u003cli\u003eBottom Legnth w\/Tabs: 20-7\/8 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 4 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 3 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 3 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 8 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height: 1.5 inches\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Height: 1.5 inches\u003c\/li\u003e\n\u003cli\u003eTop Tunnel Width: 1-13\/16 inches\u003c\/li\u003e\n\u003cli\u003eBottom Tunnel Width: 1-13\/16 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Length: 17 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use with Mini Petcock Straight With Reserve.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Ratcheting Style Gas Cap Vented.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552812892318,"sku":"38-0172","price":309.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0172-koffin-style-2-2-gallon-gas-tank-1.jpg?v=1792131975","url":"https:\/\/chopcult.com\/products\/koffin-style-2-2-gallon-gas-tank-v-twin-38-0172","provider":"ChopCult","version":"1.0","type":"link"}
