{"product_id":"knucklehead-74-engine-case-set-natural-v-twin-10-0945","title":"Knucklehead 74 Engine Case Set Natural - V-Twin 10-0945","description":"\u003cp\u003e74 inch motor case for knucklehead motors accurately cast and machined. Features a natural cast finish and a blank number boss. Manufacturer's Bill of Sale available upon request.\u003c\/p\u003e\n\u003cp\u003eCase set is designed for replacement of the original cases. No serial numbers are provided with these case sets. A Bill of Sale will be issued for blank cases. Case sets do not include pinion and sprocket shaft races. Case is made in Germany by Motortechnic and features the original detail in the casing. *NOTE: Numeral inch7 inch stamped on rear motor mount halves to denote 74 cubic inch.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eVarious crankcase main race measurements left race removed from crankcase: measurement was taken from the inside seat surface (where it would rest against the case) to the\u003c\/li\u003e\n\u003cli\u003eoutside surface toward the flywheel thrust washer. Case race.2025 Sifton measured.2045 Eastern measured.2075.\u003c\/li\u003e\n\u003cli\u003eRight race removed from crankcase: measurement was taken from the inside seat surface (where it would rest against the case) to the outside surface toward the flywheel\u003c\/li\u003e\n\u003cli\u003ethrust washer. Case race.325 Sifton measured.3245 Eastern measured.3615.\u003c\/li\u003e\n\u003cli\u003e*NOTE: We removed both races proper then installed a.024 thick thrust ring behind each case race. Worked excellent!\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Sprocket Left Side Case Race Standard.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1941-1947\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Motortechnic","offers":[{"title":"Default Title","offer_id":67549224534174,"sku":"10-0945","price":4539.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/10-0945a.jpg?v=1791646245","url":"https:\/\/chopcult.com\/products\/knucklehead-74-engine-case-set-natural-v-twin-10-0945","provider":"ChopCult","version":"1.0","type":"link"}
