{"product_id":"king-3-2-gallon-gas-tank-wyatt-gatling-38-0274-lin","title":"King 3.2 Gallon Gas Tank - Wyatt Gatling 38-0274 LIN","description":"\u003cp\u003e\u003cstrong\u003eWyatt Gatling #:\u003c\/strong\u003e 38-0274 LIN\u003c\/p\u003e\n\u003cp\u003eKing gas tank is carburetor type with a left side petcock. Tank has a fuel capacity of 3.2 gallons.\u003c\/p\u003e\n\u003cp\u003e*NOTE: Has external threads for the petcock. Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Check the petcock opening making sure the petcock can be easily installed. Petcock fitting should be masked or plugged for easy installation of petcock. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eCenter to Center: 14-5\/8 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 2-1\/4 inches\u003c\/li\u003e\n\u003cli\u003eCenter Width: 2-5\/8 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 1-3\/8 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eSuggested to use with Kreem Gas Tank Combo Kit.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552817119390,"sku":"38-0274","price":259.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0274-king-3-2-gallon-gas-tank-wyatt-gatling-38-0274-lin-1.jpg?v=1792132014","url":"https:\/\/chopcult.com\/products\/king-3-2-gallon-gas-tank-wyatt-gatling-38-0274-lin","provider":"ChopCult","version":"1.0","type":"link"}
