{"product_id":"jims-m8-valve-spring-compression-tool-jims-5835-twin-cam-2017","title":"Jims M8 Valve Spring Compression Tool - Jims 5835 - Twin Cam 2017+","description":"\u003cp\u003e\u003cstrong\u003eJims #:\u003c\/strong\u003e 5835\u003c\/p\u003e\n\u003cp\u003eJims inchon bike inch valve spring compressor tool is for use on M8 models.\u003c\/p\u003e\n\u003cp\u003eFor use when changing valve springs for performance upgrades or simply replacing a leaking valve seal. This inchon bike inch valve spring compressor kit for M8 engines works with the cylinder head installed on the motor. Simply remove the rocker box covers and rocker arms and install this unique compressor on the rocker arm shaft. Once the cylinder is filled with compressed air the technician can easily rotate the tool and compress the top collar of the valve spring exposing the keepers to remove the top collar valve spring and seal.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e2017-UP\u003c\/td\u003e\n\u003ctd\u003eFLT\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e2018-UP\u003c\/td\u003e\n\u003ctd\u003eFXST\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/16\/16-5835.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Jims","offers":[{"title":"Default Title","offer_id":67550143709342,"sku":"16-5835","price":299.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/16-5835a.jpg?v=1791663765","url":"https:\/\/chopcult.com\/products\/jims-m8-valve-spring-compression-tool-jims-5835-twin-cam-2017","provider":"ChopCult","version":"1.0","type":"link"}
