Universal Cycle
Indented Frisco Sportster Gas Tank
This custom indented Sporty is a great fit for your slick chopper or bobber. The indented scalloped sides add depth to the tank sides. The Frisco tunnel keeps the tank sitting high and the hidden mounts preserve the clean lines. Mounts will need to be cut and welded to the frame.
Features:
- Requires 1982 and later style thread in vented gas cap
- 3/8” NPT petcock bung on left side
- 2.3 gallon capacity
- Includes hidden mounting kit
Dimensions
- 16” long X 9” wide x 7.5” tall
- Tunnel is 2.25” wide x 4.5” at deepest point
Disclaimer:
Tanks are pressure tested at the factory, but it is best to test again before you paint it. Be sure fit of tank, mounting hardware, petcocks and gas caps are true prior to painting. No stress is applied to the tabs when bolting them to the frame, this can lead to cracking of welds. If needed, use leather or rubber washes to shim between the tabs and the backbone to ensure an even fit. Do not sand seams or welded edges of gas tanks, if needed use a thin spread of body filler prior to painting. Throttle Addiction warranties gas tank defects however we do not cover paint work. Ensure your tank arrived damage free BEFORE you paint!
