{"product_id":"ignition-points-set-volt-tech-a-32658-30-oem-32658-30","title":"Harley Big Twin Ignition Points Set - Volt Tech A-32658-30 - OEM 32658-30","description":"\u003cp\u003eSet of electrical contacts that switch the coil on and off at the proper time. The mechanical action of the distributor shaft lobes pushes the points open and closed. For use with braided points wire. It is suggested to double up the contact wire to take up the extra slack fold wire over on itself and press down into the fiber channel to avoid a short. Use flathead screws to mount points as supplied. *NOTE: The spring is.583 inch -.585 inch long with a.230 inch outer diameter and.165 inch inner diameter. Fits 1930-1947 Harley Flathead and Knucklehead models.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eVolt Tech #:\u003c\/strong\u003e A-32658-30 · \u003cstrong\u003eOEM #:\u003c\/strong\u003e 32658-30, 1569-30A\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\n\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1936-1947\u003c\/td\u003e\n\u003ctd\u003eEL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1941-1947\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1930-1935\u003c\/td\u003e\n\u003ctd\u003eVL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1936-1947\u003c\/td\u003e\n\u003ctd\u003eW\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Volt Tech","offers":[{"title":"Default Title","offer_id":67551688327326,"sku":"32-0120","price":29.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/32-0120-ignition-points-set-volt-tech-a-32658-30-oem-32658-30-1.jpg?v=1792121743","url":"https:\/\/chopcult.com\/products\/ignition-points-set-volt-tech-a-32658-30-oem-32658-30","provider":"ChopCult","version":"1.0","type":"link"}
