{"product_id":"ignition-coil-45-000-volts-2-7-ohms-standard-motor-products-mc-ic2x-oem-31655-99","title":"Harley Big Twin \u0026 Sportster Ignition Coil 45,000 Volts 2.7 OHMS - Standard Motor Products MC-IC2X - OEM 31655-99","description":"\u003cp\u003eBlue Streak dual fire ignition coil features a quick rise time for easier starts. The coil will enhance the performance of the motorcycles ignition system. The ignition coil features high RPM range more spark energy 45 000 + volts for maximum performance vibration resistant rapid heat dissipation for longer life under severe conditions and compatible with stock ignitions. Coil is smaller and lighter than stock and fits into stock mounting bracket. For carburetor models only. **NOTE:Check the coil primary resistance requirements from the manufacturers of the ignition being used. Fits 2000-2006 Harley Dyna, Softail, Sportster, and Touring models.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eStandard Motor Products #:\u003c\/strong\u003e MC-IC2X · \u003cstrong\u003eOEM #:\u003c\/strong\u003e 31655-99\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\n\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e2000-2006\u003c\/td\u003e\n\u003ctd\u003eFLST\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e2000-2006\u003c\/td\u003e\n\u003ctd\u003eFLT\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e2000-2006\u003c\/td\u003e\n\u003ctd\u003eFXD\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e2000-2006\u003c\/td\u003e\n\u003ctd\u003eFXST\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e2000-2006\u003c\/td\u003e\n\u003ctd\u003eXL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Standard Motor Products","offers":[{"title":"Default Title","offer_id":67551776604318,"sku":"32-0769","price":129.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/32-0769-ignition-coil-45-000-volts-2-7-ohms-standard-motor-products-mc-ic2x-oem-31655-99-1.jpg?v=1792122181","url":"https:\/\/chopcult.com\/products\/ignition-coil-45-000-volts-2-7-ohms-standard-motor-products-mc-ic2x-oem-31655-99","provider":"ChopCult","version":"1.0","type":"link"}
