{"product_id":"front-fender-raw-steel-wyatt-gatling-090531","title":"Harley Front Fender Raw Steel - Wyatt Gatling 090531","description":"\u003cp\u003eRaw front fender, a direct replacement for a dented, rusted, or missing stock fender. Universal fit for most Harley fender applications.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eWyatt Gatling #:\u003c\/strong\u003e 090531\u003c\/p\u003e\n\u003cp\u003eWyatt front fender is 2mm thick raw steel laser cut from full piece blanks.\u003c\/p\u003e\n\u003cp\u003eThe outer diameter of the bracket is 8 inch. Inside width of the fender is 4-7\/8 inch. Fender has a 140° radius and not drilled. For use on 21 inch wheels. Spacers are required if using this fender on 41mm forks. We suggest pre fitting the fender prior to painting. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eDegree: 140\u003c\/li\u003e\n\u003cli\u003eOuter Diameter: 8 inches\u003c\/li\u003e\n\u003cli\u003eInside Width of Dia.: 4-7\/8 inches\u003c\/li\u003e\n\u003cli\u003eLength: 24-3\/4 inches\u003c\/li\u003e\n\u003cli\u003eInner Width for Tire: 5-15\/16 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67553988575390,"sku":"50-0521","price":119.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/50-0521-front-fender-raw-steel-wyatt-gatling-090531-1.jpg?v=1792139910","url":"https:\/\/chopcult.com\/products\/front-fender-raw-steel-wyatt-gatling-090531","provider":"ChopCult","version":"1.0","type":"link"}
