{"product_id":"front-fender-gunfire-raw-steel-wyatt-gatling-090502","title":"Harley Front Fender Gunfire Raw Steel - Wyatt Gatling 090502","description":"\u003cp\u003eRaw front fender, a direct replacement for a dented, rusted, or missing stock fender. Universal fit for most Harley fender applications.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eWyatt Gatling #:\u003c\/strong\u003e 090502\u003c\/p\u003e\n\u003cp\u003eWyatt Gatling front fender is constructed from 1.5mm raw steel.\u003c\/p\u003e\n\u003cp\u003eFender is designed for custom applications no mounting holes are drilled. Fender has 180° coverage with built in 4-1\/8 inch wide brackets. Fender is 4-1\/4 inch wide at the ends and gradually widens to 7-3\/8 inch at the fender mounts. The fender measures 24 inch from front to back. Spacers are required for use on 41mm glide forks with 21 inch wheels. We suggest pre-fitting fender prior to painting. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67553981169822,"sku":"50-0390","price":74.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/50-0390-front-fender-gunfire-raw-steel-wyatt-gatling-090502-1.jpg?v=1792139847","url":"https:\/\/chopcult.com\/products\/front-fender-gunfire-raw-steel-wyatt-gatling-090502","provider":"ChopCult","version":"1.0","type":"link"}
