{"product_id":"forward-brake-control-kit-hydraulic-v-twin-22-0500","title":"Harley Shovelhead Forward Brake Control Kit Hydraulic - V-Twin 22-0500","description":"\u003cp\u003eForward brake control kit — pedal and the mounting hardware needed to run a hydraulic rear brake — a direct replacement for a worn-out or missing factory control setup. Fits 1970-1978 Harley Shovelhead models.\u003c\/p\u003e\n\u003cp\u003eKit is equipped for models powered by Shovelhead or Evolution engines and with hydraulic brake system.\u003c\/p\u003e\n\u003cp\u003eIncludes brake pedal pedal stop plate brake line support bracket master cylinder spacer brake pedal plunger clevis pins and pedal mounting plate. Footboards can be fitted to this kit.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eSuggested to use brake hose on the front for FXST. Suggested to use rear brake hose for disc brake. Suggested to use brake tee.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1970-1978\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/22\/22-0500.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67550949015710,"sku":"22-0500","price":169.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/22-0500-forward-brake-control-kit-hydraulic-1.jpg?v=1792111738","url":"https:\/\/chopcult.com\/products\/forward-brake-control-kit-hydraulic-v-twin-22-0500","provider":"ChopCult","version":"1.0","type":"link"}
