{"product_id":"fl-fat-bob-gas-tank-kit-3-5-gallon-v-twin-38-1959","title":"FL Fat Bob Gas Tank Kit 3.5 Gallon - V-Twin 38-1959","description":"\u003cp\u003eBobbed gas tank kit includes a 3.5 gallon capacity gas tank set with emblem mounts welded in place. Kit includes 1959 - 1960 emblems with screws gas cap set shifter lever with ball 4 speed shifter gate and a zinc gas tank mount kit.\u003c\/p\u003e\n\u003cp\u003eFor hand shift applications. Accepts a 3\/8 inch NPT petcock with male threads not included. Opening is left side forward on tank. Features provisions to accept early caps reserve shut off rod and two or three light dash not included. Check the shut off opening making sure the shut off valve can be easily installed. The shut off fitting should be masked or plugged during painting for easy installation of the shut off valve. Check the tank for flaws and fit before painting. Do not grind or sand seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. All tanks or tank sets require hand fitting to give correct alignment for dash and fuel line fitments. Dash will also have to be shimmed when installed to achieve correct height. Tank mount kit not included order separately.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003e*NOTE: UPS may consider this part as packaged inchoversizeinch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1948-1984\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67552865878174,"sku":"38-1959","price":519.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-1959-fl-fat-bob-gas-tank-kit-3-5-gallon-1.jpg?v=1792132562","url":"https:\/\/chopcult.com\/products\/fl-fat-bob-gas-tank-kit-3-5-gallon-v-twin-38-1959","provider":"ChopCult","version":"1.0","type":"link"}
