{"product_id":"fat-bob-gas-tank-set-3-5-gallon-v-twin-38-0892","title":"Fat Bob Gas Tank Set 3.5 Gallon - V-Twin 38-0892","description":"\u003cp\u003eBobbed gas tank set features provisions to accept early caps reserve shut off rod and two or three light dash. Tank has emblem mount strips attached. Order emblem set separately.\u003c\/p\u003e\n\u003cp\u003eTank emblem mount screws not included. Tank features indents for shifter gate and has a welded on shifter handle tab. Check the shut off opening making sure the shut off valve can be easily installed. Shut off fitting should be masked or plugged during the painting for easy installation of shut off valve. Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. All tanks or tank sets require hand fitting to give correct alignment for dash and fuel line fitment. Dash will also have to be shimmed when installed to achieve correct height. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use Kreem gas tank combo kit.\u003c\/li\u003e\n\u003cli\u003eSuggested to use or gas caps.\u003c\/li\u003e\n\u003cli\u003eSuggested to use shift gate for 4-speed transmissio n.\u003c\/li\u003e\n\u003cli\u003eSuggested to use shift gate for 3-speed transmissio n.\u003c\/li\u003e\n\u003cli\u003eFeatures updated design to match OEM shape and contours.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1959-1960\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552856572062,"sku":"38-0892","price":269.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0892-fat-bob-gas-tank-set-3-5-gallon-1.jpg?v=1792132425","url":"https:\/\/chopcult.com\/products\/fat-bob-gas-tank-set-3-5-gallon-v-twin-38-0892","provider":"ChopCult","version":"1.0","type":"link"}
