{"product_id":"fat-bob-gas-tank-kit-3-5-gallon-v-twin-38-0569","title":"Fat Bob Gas Tank Kit 3.5 Gallon - V-Twin 38-0569","description":"\u003cp\u003eBobbed gas tank kit includes a 3.5 gallon capacity gas tank set with emblem mounts welded in place 1955-1956 emblems with screws gas cap set and a 4 speed shifter gate.\u003c\/p\u003e\n\u003cp\u003eShifter lever with ball and zinc gas tank mount kit are not included and must be purchased separately. Kit features provisions to accept reserve shut off rod not included. Kit is for hand shift applicatons and will accept 3\/8 inch NPT petcock with male threads not included. Opening is on the left side forward on the tank. *NOTE: Check the shut off opening making sure the shut off valve can be easily installed. The shut off fitting should be masked or plugged during painting for easy installation of the shut off valve. Check the tank for flaws and fit before painting. Do not grind or sand seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. All tanks or tank sets require hand fitting to give correct alignment for dash and fuel line fitment. Dash will also have to be shimmed when installed to achieve correct height.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003e*NOTE: UPS may consider this part as packaged inchoversizeinch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/li\u003e\n\u003cli\u003e*NOTE: Fat Bob tank kit is a right and left two piece kit. Tanks are supplied in a raw oiled finish.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1948-1984\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552832258206,"sku":"38-0569","price":439.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0569-fat-bob-gas-tank-kit-3-5-gallon-1.jpg?v=1792132194","url":"https:\/\/chopcult.com\/products\/fat-bob-gas-tank-kit-3-5-gallon-v-twin-38-0569","provider":"ChopCult","version":"1.0","type":"link"}
