{"product_id":"fat-bob-3-5-gallon-gas-tank-set-v-twin-38-0183","title":"Fat Bob 3.5 Gallon Gas Tank Set - V-Twin 38-0183","description":"\u003cp\u003eGas tank set accepts left side petcock with 3\/8 inch NPT thread and has a fuel capacity of 3.5 gallons. The right side tank has 1\/8 inch FNPT thread for fuel crossover tube. Tanks do not have emblem mounts.\u003c\/p\u003e\n\u003cp\u003eBobbed two piece gas tank set features handshift mounts. Accepts 1936-1946 type cateye dash panel. Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. Petcock fitting should be masked or plugged during painting for easy installation of the petcock. All tanks or tank sets will require hand fitting to give correct alignment for dash and fuel line fitment. Dash will also have to be shimmed when installed to achieve correct height. Tanks accepts cateye style dashes only. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 18-1\/4 inches\u003c\/li\u003e\n\u003cli\u003eBottom Length: 17-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 2-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 4-3\/4 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 1-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 8 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height:\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Height:\u003c\/li\u003e\n\u003cli\u003eTunnel Length:\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use Kreem gas tank combo kit.\u003c\/li\u003e\n\u003cli\u003eSuggested to use shift gate for 4-speed transmissions.\u003c\/li\u003e\n\u003cli\u003eSuggested to use shift gate for 3-speed transmissions.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1936-1939\u003c\/td\u003e\n\u003ctd\u003eEL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552813023390,"sku":"38-0183","price":539.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0183-fat-bob-3-5-gallon-gas-tank-set-1.jpg?v=1792131978","url":"https:\/\/chopcult.com\/products\/fat-bob-3-5-gallon-gas-tank-set-v-twin-38-0183","provider":"ChopCult","version":"1.0","type":"link"}
