{"product_id":"fat-bob-3-5-gallon-gas-tank-set-v-twin-38-0140","title":"Fat Bob 3.5 Gallon Gas Tank Set - V-Twin 38-0140","description":"\u003cp\u003eGas tank is a two piece set with a fuel capacity of 3.5 gallons. Tanks do not include emblem mounts.\u003c\/p\u003e\n\u003cp\u003eTank features hand shifter mounts and shut off rod provisions. Order shut off rod and seat kit separately. Tank may require fuel rod alignment before installation of shut off assembly. Check the tank for flaws or fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. Check shut off opening making sure the shut off valve can be easily installed. Shut off fitting should be masked or plugged during painting for easy installation of shut off valve. All tanks or tank sets will require hand fitting to give correct alignment for dash and fuel line fitment. Dash will also have to be shimmed when installed to achieve correct height. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 18-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eBottom Length: 17-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 2-1\/4 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 4-3\/4 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 1-1\/4 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 7-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height:\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Height:\u003c\/li\u003e\n\u003cli\u003eTunnel Length:\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use Kreem gas tank combo kit\u003c\/li\u003e\n\u003cli\u003eSuggested to use shift gate for 4-speed transmissions.\u003c\/li\u003e\n\u003cli\u003eSuggested to use shift gate for 3-speed transmissions.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1941-1946\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552812761246,"sku":"38-0140","price":369.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0140-fat-bob-3-5-gallon-gas-tank-set-1.jpg?v=1792131972","url":"https:\/\/chopcult.com\/products\/fat-bob-3-5-gallon-gas-tank-set-v-twin-38-0140","provider":"ChopCult","version":"1.0","type":"link"}
