{"product_id":"fat-bob-3-5-gallon-gas-tank-set-raw-v-twin-38-1937","title":"Fat Bob 3.5 Gallon Gas Tank Set Raw - V-Twin 38-1937","description":"\u003cp\u003e2025 New Production raw steel gas tank set is for use with UL models and accepts NPT petcocks. Gas tanks are 3-1\/2 gallons for the right and left side. For Big Twin Flathead models.\u003c\/p\u003e\n\u003cp\u003eGas tank set features ribbed inside panels and a rounded indent on the left side of the tank. The reinforced ribs on the left side are pressed on for durability which was an upgraded feature for the 1941-1946 models. The right side does not have the indented ribs. Gas tank does not have a shut off rod provision in the left side. Requires 2 petcocks one for the left side and one for right side. Threads for petcocks are 3\/8 inch x 18 NPT for left side and 1\/8 inch x 27 NPT for the right side. Bayonet cap spigots are shorter than the late model versions as on 1965-1972 FLH. *NOTE: Tanks use 2 vented caps. *NOTE: Tank set accepts cateye or early skull type dash and base assemblies and early 1937-1946 type shifter gates. Emblem mount strips not included available separately. 1936-1939 models used decals for gas tanks - restorer may add emblem mount strips if desired.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eRequired to use with Zinc Plated Right Side Petcock.\u003c\/li\u003e\n\u003cli\u003eRequired to use with Zinc Plated Left Side Petcock.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Replica Eaton Vented Gas Cap Set.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1937-1940\u003c\/td\u003e\n\u003ctd\u003eUL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552863649950,"sku":"38-1937","price":659.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-1937-fat-bob-3-5-gallon-gas-tank-set-raw-1.jpg?v=1792132554","url":"https:\/\/chopcult.com\/products\/fat-bob-3-5-gallon-gas-tank-set-raw-v-twin-38-1937","provider":"ChopCult","version":"1.0","type":"link"}
