{"product_id":"extreme-heavy-duty-left-side-main-bearing-kit-eastern-a-24004-03b-oem-24004-03b-twin-cam-2003","title":"Extreme Heavy Duty Left Side Main Bearing Kit - Eastern A-24004-03B - OEM 24004-03B - Twin Cam 2003+","description":"\u003cp\u003e\u003cstrong\u003eEastern #:\u003c\/strong\u003e A-24004-03B · \u003cstrong\u003eOEM #:\u003c\/strong\u003e 24004-03B\u003c\/p\u003e\n\u003cp\u003eExtreme duty left side main bearing kit is for all 2003-UP Twin Cam and M8 models. Includes bearing spacer thrust washers and snap ring.\u003c\/p\u003e\n\u003cp\u003eWhen high-performance engine modifications are made the increased torque is transferred via the crankshaft to the drive system putting a significantly higher load on the bearing. The extreme duty bearing is case hardened on the inner and outer race to provide increased load capacity and enhanced durability in high-torque applications. Installed in the left side of the crank case and supports the output shaft to the primary drive system.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e2003-2017\u003c\/td\u003e\n\u003ctd\u003eFLST\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e2003-UP\u003c\/td\u003e\n\u003ctd\u003eFLT\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e2003-2017\u003c\/td\u003e\n\u003ctd\u003eFXD\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e2003-2017\u003c\/td\u003e\n\u003ctd\u003eFXST\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/10\/10-0346.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Eastern","offers":[{"title":"Default Title","offer_id":67549198516382,"sku":"10-0346","price":109.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/10-0346a.jpg?v=1791645641","url":"https:\/\/chopcult.com\/products\/extreme-heavy-duty-left-side-main-bearing-kit-eastern-a-24004-03b-oem-24004-03b-twin-cam-2003","provider":"ChopCult","version":"1.0","type":"link"}
