{"product_id":"engine-pinion-shaft-eastern-a-24006-39-oem-24006-39","title":"Engine Pinion Shaft - Eastern A-24006-39 - OEM 24006-39","description":"\u003cp\u003e\u003cstrong\u003eEastern #:\u003c\/strong\u003e A-24006-39 · \u003cstrong\u003eOEM #:\u003c\/strong\u003e 24006-39\u003c\/p\u003e\n\u003cp\u003ePrecision ground for correct fitment.\u003c\/p\u003e\n\u003cp\u003e*NOTE: Check spline timing in relation to key way slot. Turn shaft so that the key way slot is at 12 o'clock on shaft. Oil hole and large spline should be at the 3 o'clock position before installing in flywheel for final assembly.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1939-1940\u003c\/td\u003e\n\u003ctd\u003eEL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1941-1953\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Eastern","offers":[{"title":"Default Title","offer_id":67549199433886,"sku":"10-0400","price":119.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/10-0400a.jpg?v=1791645656","url":"https:\/\/chopcult.com\/products\/engine-pinion-shaft-eastern-a-24006-39-oem-24006-39","provider":"ChopCult","version":"1.0","type":"link"}
