{"product_id":"engine-gasket-kit-gary-bang-p400195900898-oem-17029-79","title":"Harley Big Twin Engine Gasket Kit - Gary Bang P400195900898 - OEM 17029-79","description":"\u003cp\u003eComplete engine gasket kit includes all of the gaskets seals and o-rings necessary to rebuild Shovelhead 4-speed engine. Includes teflon head gasket front and rear cylinder base gasket rocker cover gaskets front and rear tappet gaskets cam cover and derby cover gaskets oil pump body paper gasket oil pump outer cover paper gasket oil pump case paper gasket oil pump cover paper gasket carburetor mount base gaskets air cleaner mount gasket point cover gasket starter hole gasket 1\/32 inch primary cover gasket inspection plate gasket solenoid mount gasket copper dual exhaust gasket starter deflector gasket rocker arm o-rings oil cap o-ring v-2 middle pushrod o-rings large pushrod quad seal small flat pushrod o-rings clutch hub nut seal left engine seal manifold seals cam cover seal rocker line oiler seals starter shaft housing seal oil pump seal and inner primary o-ring. Fits 1978-1984 Harley Big Twin, FX (Super Glide), FXR, Touring, and Shovelhead models.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eGary Bang #:\u003c\/strong\u003e P400195900898 · \u003cstrong\u003eOEM #:\u003c\/strong\u003e 17029-79\u003c\/p\u003e\n\u003cp\u003eComplete engine gasket kit includes all of the gaskets seals and o-rings necessary to rebuild Shovelhead 4-speed engine.\u003c\/p\u003e\n\u003cp\u003eIncludes teflon head gasket front and rear cylinder base gasket rocker cover gaskets front and rear tappet gaskets cam cover and derby cover gaskets oil pump body paper gasket oil pump outer cover paper gasket oil pump case paper gasket oil pump cover paper gasket carburetor mount base gaskets air cleaner mount gasket point cover gasket starter hole gasket 1\/32 inch primary cover gasket inspection plate gasket solenoid mount gasket copper dual exhaust gasket starter deflector gasket rocker arm o-rings oil cap o-ring v-2 middle pushrod o-rings large pushrod quad seal small flat pushrod o-rings clutch hub nut seal left engine seal manifold seals cam cover seal rocker line oiler seals starter shaft housing seal oil pump seal and inner primary o-ring.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1978-1984\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1979-1983\u003c\/td\u003e\n\u003ctd\u003eFLT\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1978-1984\u003c\/td\u003e\n\u003ctd\u003eFX\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1982-1983\u003c\/td\u003e\n\u003ctd\u003eFXR\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Gary Bang","offers":[{"title":"Default Title","offer_id":67549740826782,"sku":"15-0511","price":99.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/15-0511-engine-gasket-kit-gary-bang-p400195900898-oem-17029-79-1.jpg?v=1792105820","url":"https:\/\/chopcult.com\/products\/engine-gasket-kit-gary-bang-p400195900898-oem-17029-79","provider":"ChopCult","version":"1.0","type":"link"}
