{"product_id":"dynatek-fusion-efi-ignition-module-dyna-tek-dfe-15-021-twin-cam-softail-2012-2015","title":"Harley Dynatek Fusion EFI Ignition Module - Dyna Tek DFE-15-021 - Twin Cam Softail 2012-2015","description":"\u003cp\u003eDyna Fusion EFI module with fuel and ignition control is available for most models. The new Dynatek Fusion EFI bases fuel adjustments on input from RPM and throttle positions. Fuel delivery and spark advance adjustments can now be made with the Dynatek Fusion module. The Fusion EFI has 250 RPM resolution and 10 throttle position columns giving you up to 640 individual mapping points for fuel and an equal amount for ignition timing. This is the kind of inchpoint specific inch adjustability that is necessary with today's bikes and the parts that are available for them. This module features individual cylinder and gear position mapping a built in two position map switching function inchwarm up inch fuel adjustments based on engine temperature an enhanced inchaccel pump inch utility and is USB powered from computer. It also allows +\/- 20 degrees of timing adjustments per cylinder or per gear. *NOTE: Not for sale in California. Fits 2012-2015 Harley Softail models.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eDyna Tek #:\u003c\/strong\u003e DFE-15-021\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\n\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e2012-2015\u003c\/td\u003e\n\u003ctd\u003eFLST\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e2012-2015\u003c\/td\u003e\n\u003ctd\u003eFXST\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Dyna Tek","offers":[{"title":"Default Title","offer_id":67551784960158,"sku":"32-1174","price":419.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/32-1174-dynatek-fusion-efi-ignition-module-dyna-tek-dfe-15-021-twin-cam-softail-2012-2015-1.jpg?v=1792122444","url":"https:\/\/chopcult.com\/products\/dynatek-fusion-efi-ignition-module-dyna-tek-dfe-15-021-twin-cam-softail-2012-2015","provider":"ChopCult","version":"1.0","type":"link"}
