{"product_id":"dyna-mini-coil-set-0-5-ohms-single-output-towers-dyna-tek-dc12-2","title":"Harley Dyna Mini Coil Set 0.5 Ohms Single Output Towers - Dyna Tek DC12-2","description":"\u003cp\u003eDyna miniature coil set feature single output towers and.5 ohms primary resistance. Designed for use with Dyna TC-88 series ignitions and should not be used with Dyna S ignition systems. Coil set measures 4.2 inch x 2.3 inch x 1.6 inch withmounting centers of 2.9 inch minimum to 3.5 maximum and black housing. Replaces Dyna DC12-2. **NOTE:Check the coil primary resistance requirements from the manufacturers of the ignition being used. Universal fit for most Harley applications.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eDyna Tek #:\u003c\/strong\u003e DC12-2\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\n\u003cul\u003e\u003cli\u003eNot for use with Dyna S ignitions\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\n\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eSpecial\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Dyna Tek","offers":[{"title":"Default Title","offer_id":67551872254110,"sku":"32-9344","price":139.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/32-9344-dyna-mini-coil-set-0-5-ohms-single-output-towers-dyna-tek-dc12-2-1.jpg?v=1792124107","url":"https:\/\/chopcult.com\/products\/dyna-mini-coil-set-0-5-ohms-single-output-towers-dyna-tek-dc12-2","provider":"ChopCult","version":"1.0","type":"link"}
