{"product_id":"dyna-12-volt-3-ohm-dual-fire-coil-dyna-tek-dc1-1","title":"Harley Dyna 12 Volt 3 Ohm Dual Fire Coil - Dyna Tek DC1-1","description":"\u003cp\u003eThis Dyna dual fire coil is angle type. The coil is 12 volt and 3 ohm will produce spark voltages in excess of 30 000 volts and sparks energies second to none. Replaces Dyna DC-1. This coil works with points ignition aftermarket and factory electronic ignitions. Sold in a quantity of two. **NOTE:Check the coil primary resistance requirements from the manufacturers of the ignition being used. Universal fit for most Harley applications.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eDyna Tek #:\u003c\/strong\u003e DC1-1\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003eCoil Length: 4.61 inches\u003c\/li\u003e\n\u003cli\u003eCoil Width: 2.9 inches\u003c\/li\u003e\n\u003cli\u003eCoil Height: 1.95 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\n\u003cul\u003e\u003cli\u003eSuggested to use with Coil Mount for Dyna Ignitions.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\n\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eSpecial\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Dyna Tek","offers":[{"title":"Default Title","offer_id":67551855345822,"sku":"32-7789","price":209.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/32-7789-dyna-12-volt-3-ohm-dual-fire-coil-dyna-tek-dc1-1-1.jpg?v=1792145000","url":"https:\/\/chopcult.com\/products\/dyna-12-volt-3-ohm-dual-fire-coil-dyna-tek-dc1-1","provider":"ChopCult","version":"1.0","type":"link"}
