Throttle Addiction
Dished Wassell Peanut Gas Tank - Mid Tunnel
The Dished Wassell Style gas tank is a throwback to sixties show bikes. The recessed dishing perfectly matches the outside lines of the tank and is formed during the stamping process. Unlike other dished tanks which cut the panels out and weld them back in reversed, our edges are perfectly smooth. Since its a one stamped piece, you won’t have to worry about any cracking at the weld seams or spend tons of time prepping for paint. The tunnel is mid depth which covers the perfect amount of frame.
Features:
- Mid depth tunnel
- Undrilled mounting tabs
- Bungs for two 1/4" NPT petcocks
- Uses vented cam style gas cap - Throttle Addiction part numbers 1010 chrome, 1109 black.
Dimensions:
- 2.1 gal capacity
- 14.5" long x 9" wide x 7.5" tall
- 17" tab to tab
- 3.5" deep tunnel
- 2.15" wide tunnel
Disclaimer:
Tanks are pressure tested at the factory, but it is best to test again before you paint it. Be sure fit of tank, mounting hardware, petcocks and gas caps are true prior to painting. No stress is applied to the tabs when bolting them to the frame, this can lead to cracking of welds. If needed, use leather or rubber washes to shim between the tabs and the backbone to ensure an even fit. Do not sand seams or welded edges of gas tanks, if needed use a thin spread of body filler prior to painting. Throttle Addiction warranties gas tank defects however we do not cover paint work. Ensure your tank arrived damage free BEFORE you paint!
