Skip to product information
1 of 6
Wyatt Gatling
Coffin Chopper Gas Tank
Regular price $214.99 USD
Regular price Sale price $214.99 USD
Sale Sold out
This custom coffin style chopper gas tank will have you cruising in vintage 70's style! Perfect for that long raked out chopper.
Features:
  • 1/4" NPT petcock bungs on left and right side of tank
  • Single front tab and a rear U-bracket
  • Fits custom application for 1-1/2" top frame tubes
Dimensions
  • 2.2 gallon capacity
  • 20" long x 9.5"" wide x 8"" tall
  • 19.5" long tab to tab
  • 1.5" deep tunnel
  • Uses late model screw in style gas cap SKU 1132
Disclaimer:
Tanks are pressure tested at the factory, but it is best to test again before you paint it.  Be sure fit of tank, mounting hardware, petcocks and gas caps are true prior to painting.  No stress is applied to the tabs when bolting them to the frame, this can lead to cracking of welds.  If needed, use leather or rubber washes to shim between the tabs and the backbone to ensure an even fit.  Do not sand seams or welded edges of gas tanks, if needed use a thin spread of body filler prior to painting.  Throttle Addiction warranties gas tank defects however we do not cover paint work.  Ensure your tank arrived damage free BEFORE you paint!
