{"product_id":"chopper-peanut-gas-tank-wyatt-gatling-38-0783-lin","title":"Chopper Peanut Gas Tank - Wyatt Gatling 38-0783 LIN","description":"\u003cp\u003e\u003cstrong\u003eWyatt Gatling #:\u003c\/strong\u003e 38-0783 LIN\u003c\/p\u003e\n\u003cp\u003eGas tank has a fuel capacity of 2.0 gallons. Tank is a single cap design with front and rear saddle style brackets to fit 1-1\/2 inch frame tubing. It can be bolted or clamped in place. Tank accepts Bayonet type caps.\u003c\/p\u003e\n\u003cp\u003eIt accepts a 1\/4 inch National Pipe Thread petcock and a stock style vented cap. Tank fits over 1-1\/2 inch frame tube. *NOTE: Features a deep tunnel. Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Check the petcock opening making sure the petcock can be easily installed. The petcock fitting should be masked or plugged during painting for easy installation of the petcock. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 14-3\/4 inches\u003c\/li\u003e\n\u003cli\u003eBottom Length: 14-1\/8 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 3-7\/8 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 8-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 2 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 7 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height: 6 inches\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Height: 1 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Length: 17-5\/8 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Width: 1-3\/4 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTab mounts must be fabricated and welded on by customer.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Chopper Peanut Gas Tank Mount Tab Set Raw.\u003c\/li\u003e\n\u003cli\u003eTedd Cycle was awarded Hap Jones distribution rights in the spring of 1976 including Avon Tyres from Hap Jones personally.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552853196958,"sku":"38-0783","price":219.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0783-chopper-peanut-gas-tank-wyatt-gatling-38-0783-lin-1.jpg?v=1792132348","url":"https:\/\/chopcult.com\/products\/chopper-peanut-gas-tank-wyatt-gatling-38-0783-lin","provider":"ChopCult","version":"1.0","type":"link"}
