{"product_id":"chopper-hummer-2-5-gallon-gas-tank-v-twin-38-1652","title":"Chopper Hummer\" 2.5 Gallon Gas Tank - V-Twin 38-1652","description":"\u003cp\u003eGas tank has a right side filler cap location a fuel capacity of 2.5 gallons and accepts a bayonet style gas cap. The tank is universal with front and rear mounting tabs.\u003c\/p\u003e\n\u003cp\u003eIt uses a 3\/8 inch National Pipe Thread style petcock pre-1975. Please test fitment before painting. Tank weld seams may require filler to meet your individual requirements. Do not grind or sand the seams as this may cause leaks. We suggest using Kreem gas tank combo kit to clean condition and seal. This will help to stop leaks and prevent corrosion. Check petcock opening masking sure the petcock can be easily installed. Petcock fitting should be masked or plugged during painting for easy installation of the petcock. The tank has underilled tab front and rear for surface mounting on top frame tube. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eFront Mount to Rear: 17-5\/8 inches\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003e*NOTE: Mounts with front and rear tabs which must be drilled by installer to 5\/16inch universal holes.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552861946014,"sku":"38-1652","price":189.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-1652-chopper-hummer-2-5-gallon-gas-tank-1.jpg?v=1792132543","url":"https:\/\/chopcult.com\/products\/chopper-hummer-2-5-gallon-gas-tank-v-twin-38-1652","provider":"ChopCult","version":"1.0","type":"link"}
