{"product_id":"chopper-axed-2-2-gallon-gas-tank-wyatt-gatling-63093d","title":"Chopper Axed 2.2 Gallon Gas Tank - Wyatt Gatling 63093D","description":"\u003cp\u003e\u003cstrong\u003eWyatt Gatling #:\u003c\/strong\u003e 63093D\u003c\/p\u003e\n\u003cp\u003eGas tank has a right side petcock opening fuel capacity of 2.2 gallons and a center cap fill. It comes with a screw-in gas cap bung and has front and rear mount tabs.\u003c\/p\u003e\n\u003cp\u003eThe petcock measures 5\/8 inch x 18 and the bung on the left side is 1\/2 inch x 20. *NOTE: Cap is on right side and uses a screw in JD gas cap available separately. Check the tank for flaws and fit before painting. It requires sanding and primer. Do not grind or sand the seams or joints. Check the petcock opening making sure the petcock can be easily installed. The petcock fitting should be masked or plugged during painting for easy installation of the petcock. The petcock must be ordered separately. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to h lp stop leaks and prevent corrosion. *Note: UPS may consider this part as p ckaged inchoversize inch for shipment as compared to the actual weight which will re ult in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eLength of Tank: 16 inches\u003c\/li\u003e\n\u003cli\u003eLength of Bottom: 14-3\/8 inches\u003c\/li\u003e\n\u003cli\u003eWidth of Rear: 3 inches\u003c\/li\u003e\n\u003cli\u003eWidth of Front: 8-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eHeight of Rear: 3 inches\u003c\/li\u003e\n\u003cli\u003eHeight of Front: 9 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height: 1-3\/4 inches\u003c\/li\u003e\n\u003cli\u003eRear Tunner Height: 4-1\/8 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Length: 13 inches\u003c\/li\u003e\n\u003cli\u003ePetcock: 5\/8 inches x 18\u003c\/li\u003e\n\u003cli\u003eLeft Side Bung: 1\/2 inches x 20\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use with JD Gas Cap Bung.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with JD Gas Cap Vented Nickel Plated.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552851493022,"sku":"38-0697","price":139.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0697-chopper-axed-2-2-gallon-gas-tank-wyatt-gatling-63093d-1.jpg?v=1792132306","url":"https:\/\/chopcult.com\/products\/chopper-axed-2-2-gallon-gas-tank-wyatt-gatling-63093d","provider":"ChopCult","version":"1.0","type":"link"}
