{"product_id":"chopper-axed-2-2-gallon-gas-tank-wyatt-gatling-63093","title":"Chopper Axed 2.2 Gallon Gas Tank - Wyatt Gatling 63093","description":"\u003cp\u003e\u003cstrong\u003eWyatt Gatling #:\u003c\/strong\u003e 63093\u003c\/p\u003e\n\u003cp\u003eGas tank has a right side petcock opening and a fuel capacity of 2.2 gallons. It uses a single bayonet style gas cap and has front and rear mount tabs.\u003c\/p\u003e\n\u003cp\u003eRight side is 3\/8 inch NPT female left side is 1\/4 inch NPT female for petcocks. Petcock tunnel is 2-1\/2 inch wide. Tabs are front and rear undrilled. Check the tank for flaws and fit before painting. It requires sanding and primer. Do not grind or sand the seams or joints. Check the petcock opening making sure the petcock can be easily installed. The petcock fitting should be masked or plugged during painting for easy installation of the petcock. The petcock must be ordered separately. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 16-1\/4 inches\u003c\/li\u003e\n\u003cli\u003eBottom Length: 14-3\/4 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 2-1\/4 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 8 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 1-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 7 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height: 3 inches\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Height: 1-1\/4 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Length: 15-5\/8 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use with Petcock Wing Type Chrome.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Stock Style Gas Cap Vented\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552851361950,"sku":"38-0693","price":199.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0693-chopper-axed-2-2-gallon-gas-tank-wyatt-gatling-63093-1.jpg?v=1792132305","url":"https:\/\/chopcult.com\/products\/chopper-axed-2-2-gallon-gas-tank-wyatt-gatling-63093","provider":"ChopCult","version":"1.0","type":"link"}
