{"product_id":"chopper-3-0-gallon-gas-tank-wyatt-gatling-63783a","title":"Chopper 3.0 Gallon Gas Tank - Wyatt Gatling 63783A","description":"\u003cp\u003e\u003cstrong\u003eWyatt Gatling #:\u003c\/strong\u003e 63783A\u003c\/p\u003e\n\u003cp\u003eSaga inchDish gas tank inch has a right side petcock opening and features dished sides. Fuel capacity is 3.0 gallons.\u003c\/p\u003e\n\u003cp\u003eIt uses a pop-up style gas cap which is not included. Check the tank for flaws and fit before painting. It requires sanding and primer. Do not grind or sand the seams or joints. Check the petcock opening making sure the petcock can be easily installed. The petcock fitting should be masked or plugged during painting for easy installation of the petcock. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condi tion and seal to help stop leaks and prevent corrosion. Accepts a 3\/8 inch NPT petcock. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 17 inches\u003c\/li\u003e\n\u003cli\u003eBottom Length: 15 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 5 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 11 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 2 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 7.75 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height: 3 inches\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Height: 1 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Length: 16.5 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eSuggested to use Kreem gas tank combo kit\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552870727838,"sku":"38-5061","price":269.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-5061-chopper-3-0-gallon-gas-tank-wyatt-gatling-63783a-1.jpg?v=1792132601","url":"https:\/\/chopcult.com\/products\/chopper-3-0-gallon-gas-tank-wyatt-gatling-63783a","provider":"ChopCult","version":"1.0","type":"link"}
